Bosten Dynamics SPOT + EDGE CPU
Item number: MBS-BD-06
  • Motherboard: i5 Intel® 8th Gen (Whiskey Lake-U)
  • Core™ CCG Lifecycle
  • Speicher (RAM): 16 GB DDR4 2666 MHz
  • Primärer Speicher: 512 GB SSD
  • Betriebssystem: Ubuntu Desktop 18.04 LTS 64-Bit
Category: Accessories
4.999,00 €
Available now!
Shipping time: 1 - 4 workdays
Spot CORE is an additional processor that allows developers to run their own software locally on the robot. Although any device connected to the Spot network can run its own code via the Spot SDK, running locally on Spot CORE can achieve a high-bandwidth, low-latency connection. This payload connects directly to the payload port for power and network connectivity and comes with the Ubuntu 18.04 operating system pre-installed with our SDK so you can start using it as soon as possible. Unlike computers in Spot, this system is open for development. If you have special system requirements, you can format the hard drive and install your own operating system. CORE is equipped with all the ports needed for fast development:
  • 3x USB 3.0
  • 2x USB 2.0
  • HDMI Ethernet Serial port RS232
  • 2x display ports
Technical Data:
  • Length: 250 mm (9.8 in)
  • Width: 190 mm (7.5 in)
  • Height: 84 mm (3.3 in)
  • Weight: 2000 g (4.4 lbs)
  • Motherboard: i5 Intel® 8th Gen (Whiskey lake-U)
  • Memory (RAM): 16 GB DDR4 2666 MHz
  • Primary storage: 512 GB SSD Operating system: Ubuntu Desktop 18.04 LTS 64-bit
  • Operating temperature: 0 to 50°C
Scope of delivery:
  • CPU
  • Mounting kit
  • Shielded ribbon cable (225 mm)
Average product review
