Boston Dynamics SPOT + EDGE GPU
Item number: MBS-BD-07
Boston Dynamics SPOT + EDGE GPU CPU:
  • Intel Xeon E3-1515M V5 CPU
  • RAM: 32 GB
  • SSD: 480GB mSATA SSD
  • GPU: NVIDIA P5000
  • Water resistance: IP67
Category: Accessories
29.499,00 €
Available now!
Shipping time: 1 - 4 workdays
The Spot CORE AI is a complete development environment for running compute-intensive tasks on Spot, such as machine learning. This payload connects directly to the power and network payload ports and comes with the Ubuntu 18.04 operating system pre-installed with our SDK so you can start using it as soon as possible. Compared to computers in Spot, the system is open to modification by developers. If you have special system requirements, you can format the hard drive and install your own operating system. Spot CORE AI cannot be compared to any other computer on the market, as it is designed for the same operating temperatures and higher protection standards as Spot itself. Use your software in the same harsh environment as Spot, from snow in winter to rain in summer.
Spot CORE AI is equipped with some of the most powerful components ever integrated into an eco-friendly system: an Intel Xeon E3-1515M and an Nvidia Quadro P5000 GPU. The CORE AI is equipped with all the connections you need for rapid development:
  • HDMI
  • 2x 1000Base-T Ethernet RJ-45
  • 2x USB3 Type A
  • 2x USB3 Type C
  • Regulated power supply: 12V 4A, 24V 2.3A, 5V 8A
  • RS232 Serial
  • MiniPCIe (internal, in some configurations occupied with LTE modem)
Technical Data:
  • Length: 240 mm (9.4 in)
  • Width: 185 mm (7.3 in)
  • Height: 74 mm (2.9 in)
  • Weight: 3.45 kg (7.6 lbs)
  • CPU: Intel Xeon E3-1515M V5 CPU
  • RAM: 32 GB
  • GPU: NVIDIA P5000
  • Operating temperature: -20 to 45°C
  • Peak power consumption: 210W
Scope of Delivery:
  • GPU
  • Mounting kit
  • Shielded ribbon cable (225 mm)
Average product review
