Boston Dynamics SPOT INSPECTION CAM+
Item number: MBS-BD-03
Boston Dynamics SPOT INSPRECTION CAM+
  • PTZ movement range: 170°/sec
  • PTZ tilt range: -30 to 270°
  • PTZ resolution: 2MP, 1080p video resolution, 30x zoom
  • Protection class: IP65
Category: Accessories
43.888,00 €
Available now!
Shipping time: 1 - 4 workdays
The Spot CAM + Payload transforms Spot into a powerful inspection tool with dedicated cameras and turnkey integration. Spot CAM+ features a color ring camera with a 360° field of view that can realize full situational awareness when remotely controlling the robot. The pan-tilt-zoom (PTZ) color camera provides a powerful 30x optical zoom for detailed remote inspections. The integrated high-sensitivity microphone and amplified speaker can realize remote acoustic inspection and two-way communication with operators on site. Spot CAM + is fully integrated with Spot's tablet controller. Stream video from the camera to safely operate your site remotely.
Use PTZ cameras to focus on remote or hazardous environments and concentrate on important inspection details. Use Spot's ready-to-use Autowalk autopilot system to capture high-quality photos manually or automatically. Spot CAM + is specifically designed to capture data in challenging environments where you don't want to walk alone. The image sensor is optimized for low-light conditions and the integrated LED lighting allows 24/7 operation.
This payload is sealed to IP65 and can operate at temperatures from -20 to 45°C, so it can be used wherever Spot needs it. Developers can use the GRPC API to further customize Spot CAM+ for their applications, which is available via the Spot SDK. Audio and video streams are transmitted via WebRTC and can be easily integrated into your application.
Technical Data:
  • Length: 334 mm (13.1 in)
  • Width: 203 mm (8.0 in)
  • Height: 330 mm (13.0 in)
  • Weight: 6.5 kg (14.3 lbs)
  • Panorama field of view: 360 x 170
  • Resolution of panorama camera: 10MP
  • Panorama image size: 9600x4800
  • Sensor of panorama camera: 5x Sony IMX290
  • Focal length of panorama lens: 2.16 mm
  • Aperture of panoramic lens:F2.0
  • PTZ tilt range: -30 to 270°.
  • Operating temperature: -20 to 45°C
  • Scope of delivery:
  • 30x optical pan-tilt-zoom camera
  • Integrated 360 color camera
  • Two-way communication
  • LED illumination
  • x3 USB sticks
  • Mounting kit
  • Shielded ribbon cable (225 mm)
HAN: Spot CAM +
Shipping weight: 10,00 Kg
Product weight: 6,50 Kg
Average product review
