Clearpath UGV Wireless Charging Kit
Item number: MBS-Z-120
  • Programmable system
  • Weatherproof housing
  • Transmitter and receiver for the Jackle or Husky
Category: Accessories
starting from 6.049,00 €
Recommended retail price: 6.049,00 €
Available now!
There are variations of this item. Please select the variation you wish.
The UGV kit for the Clearpath Jackal / Husky for wireless charging
Reliable autonomous wireless charging
These kits include everything you need to retrofit a Clearpath Jackal or Husky UGV with Wibotic's industry-leading wireless charging system for autonomous robots.
Key Features:
  • Fully autonomous wireless charging for streamlined and efficient automated processes.
  • Weatherproof housing enables reliable operation in wet, dirty and corrosive environments.
  • Programmable system ensures battery is charged properly to maximize battery life.
  • Universal design allows different Clearpath robots to use the same charging infrastructure, regardless of battery chemistry, voltage and/or charging speed.
  • Fleet management software (optional) gives operators key insights into the charging network. Easily monitor an entire network of charging stations serving a fleet of robots and know when a station is available.
Technical specifications:
TR-110 Edge Transmitter
  • Input voltage (AC) 90-264v
  • Input socket IEC320-C14
  • Input frequency 50-60 Hz
  • Housing type ABS plastic/metal
  • Data port Ethernet (RJ45)
OC-110 Onboard charger
(Differences are possible depending on which device you need it for)
  • Battery Compatibility LiPO, Lilon, SLA, LiFeP04, NMH, NiCAD
  • Battery voltage range 7.92 - 30.1 V DC or 8 - 58.4v (depending on device selection)
  • Max. Charging current 5A - 12A (depending on device selection)
  • Charging power 90 W - 300 W (depending on device selection)
  • Total weight (with case) 101g - 580g (depending on device selection)
  • Operating temperature -20 to 45C or - to 45C (depending on device selection)
  • Transmitter/receiver communication UAVCAN API via CAN bus
  • Aux Wired charging Input voltage 18-50V DC or 24-50V DC (depending on device selection)
  • Cooling method Active or Passive (depending on device selection)
  • IP protection class IP20
Included in the kit:
  • WiBotic transmitter
  • WiBotic receiver (on robot)
  • Customized brackets for receiver coil Onboard charger
  • Instruction for integration
Average product review
