DA233 multi-band GNSS Antenna
Item number: MBS-SES-168
DA233 Multiband GNSS Antenna.
  • Multiband GPS coverage:
    • L1/L2, GLONASS G1/G2,
    • BEIDOU B1/B2/B3
    • Galileo E1/E5b/E6
  • Faster initialization thanks to more available satellites.
Category: UAV / Pixhawk
89,95 €
Available now!
Shipping time: 6 - 9 workdays
DA233 is a low cost and efficient active multiband GNSS antenna. The GNSS active antenna features high gain, extremely low elevation gain and circular polarization. The DA233 is also well suited for precise positioning in the three-frequency range and uses a multi-feed-point design to ensure phase center and geometric center overlap. The device can receive GPS, GLONASS, Beidou and Galileo signals simultaneously to improve signal availability. Due to its wide radiation pattern, the DA233 multi-band GNSS antenna can receive strong signals even in hidden locations. It is waterproof, anti-ultraviolet, high temperature and low temperature resistance. The minimum peak gain of 2 dBi is boosted by 39 dB LNA to ensure the best signal quality in any situation.
Thanks to its wide radiation pattern, DA233 multiband GNSS antenna enables strong signal pickup even in protected locations. It is waterproof, UV resistant and resistant to high and low temperatures.
To ensure the best signal quality in any situation, the minimum 2dBi peak gain is amplified by a 39dB LNA.
Scope of delivery:
  • 1x DA233 multi-band GNSS Antenna
Average product review
