DYNAMIXEL Pro+ H54P-200-S500-R
General
The ROBOTIS Dynamixel Pro+ servos have different power values, dimensions and interfaces and therefore cover a wide field of possible applications. The Dynamixel Pro+ H54P-200-S500-R has an epicyclic gearing aswell as an integrated encoder that enables up to 1 003 846 steps/pulse. Furthermore the Dynamixel Pro servos have following special functions:
Technical Data
Default settings
When delivered everey DYNAMIXEL Pro servo has the ID:1 and an baudrate of 57 600bps
Delivery content
- current sensor for force control
- control algorithm for speed, position and voltage regulation
- PID-Controller for intern position control
Technical Data
- Model Name: H54P-200-S500-R
- ROBOTIS item number: 902-0079-001
- Resolution: 1 003 846 Steps/Pulse (0.0004°)
- Weight: 0,855Kg
- Dimensions: 54 x 54 x 126mm
- Working voltage: 24V
- Maximum torque: 29 RPM
- Engine type: BLDC (Maxon)
- Current: up to 9,3A
- Toruqe: 44,7Nm
- Gear ratio: 501,9:1
- Interface: RS485 (Half Duplex, 8bit, 1 Stop Bit, No Parity)
- Working temperature: -5° - 55°C
- Mode: Torque, Velocity, Position, Extended Position & PWM Control
- ID: 0 - 252
Default settings
Delivery content
- DYNAMIXEL H54P-200-S500-R
- 2 x X4P 600mm Data & Power cable
- 20 x WB M3x8mm
HAN: | 902-0079-001 |
Shipping weight: | 1,50 Kg |
Product weight: | 0,86 Kg |
