DYNAMIXEL Pro+ M54-040-S250-R
General
The ROBOTIS Dynamixel Pro servos have different power values, dimensions and interfaces and therefore cover a wide field of possible applications. The Dynamixel Pro+ M54P-040-S250-R has an epicyclic gearing aswell as an integrated encoder that enables up to 502 834 steps/pulse. Furthermore the Dynamixel Pro servos have following special functions:
Technical Data
Default settings
When delivered every DYNAMIXEL Pro servo has the ID:1 and a baudrate of 57 600bps.
Delivery content
- current sensor for force control
- control algorithm for speed, position and voltage regulation
- PID-Controller for inter position control
Technical Data
- Model Name: M54P-040-S250-R
- ROBOTIS item number: 902-0089-001
- Resolution: 502 834 Steps/Pulse
- Weight: 0,71Kg
- Dimensions: 54 x 54 x 108mm
- Working voltage: 24V
- Maximum torque: 28,4 RPM
- Current: up to 1,9A
- Torque: 3,9Nm
- Gear ratio: 251,4:1
- Interface: RS485 (Half Duplex, 8bit, 1 Stop Bit, No Parity)
- Working temperature: -5° - 55°C
- ID: 0 - 252
Default settings
Delivery content
- DYNAMIXEL M54P-040-S250-R
- 2 x 4P 600mm Data & Power cable
- 20 x WB M3x8mm
HAN: | 902-0089-001 |
Product weight: | 0,71 Kg |
