IntelŪ RealSense Depth Camera D405
Item number: MBS-SES-214
IntelŪ RealSense™ Depth Camera D405
  • IntelŪRealSense™ Vision Processor D4
  • Incl. tripod and USB cable
  • Image sensor technology: Global Shutter
  • ideal range: 7cm - 50cm
  • Depth field of view and RGB FOV (H x V): 87° x 58°.
  • depth accuracy: +/- 2% at 50cm
  • Depth output resolution and RGB frame resolution: up to 1280 x 720
  • RGB frame rate: up to 90fps
Category: 3D Machine Vision
399,95 €
Available now!
Shipping time: 1 - 4 workdays
Software
Technical Details
  • Lighting Ratios: Indoor/Outdoor
  • Temperature range: -0 to 35°C (ambient); -0 to 55°C (housing)
  • Depth technology: Stereoscopic
  • Minimum depth distance: 7cm at 480p
  • Depth accuracy: +/- 2% at 50cm
  • depth field of view: 87° x 58
  • Depth output resolution: up to 1280 x 720
  • RGB- depth technology: left imager RGB with ISP
  • RGB frame resolution: 1280 x 720
  • RGB FOV (H x V): 87° x 58°
  • Power idle: 35 mW
  • power streaming: 1.55 W (depth + IR)
  • Camera module: Intel RealSense Module D401
  • Vision Processor Board: Intel RealSense Vision Processor D4 Board v4
  • form factor: peripheral/module
  • Dimensions: 42 x 42 x 23 mm (peripheral) | 36.5 x 19.4 x 10.5 mm (module)
  • Interfaces: USB 2 | USB 3.1
  • mounting mechanism: one mounting point with 1/4-20 UNC thread | two mounting points with M3 thread | stand
  • Intel RealSense D405 Depth Camera
  • Tripod
  • USB-Cable
HAN: 82635DSD405 / 99ACXC
Shipping weight: 0,38 Kg
Average product review
Intel RealSense D405 Datasheet
