IntelŪ RealSense Depth Camera D415
Item number: MBS-SES-138
EAN: 5032037110273
IntelŪ RealSense™ Depth Camera D415
  • IntelŪRealSense™ Vision Processor D4
  • up to 1920 x 1080 RGB resolution
  • diagonal field of view over 70°
  • range 0.3 m to over 10 m (varies depending on lighting conditions)
Category: 3D Machine Vision
399,95 €
Available now!
Shipping time: 6 - 9 workdays
Software
Technical Details
  • up to 1920 x 1080 RGB-Resolution
  • FOV: 70°
  • Range: 0,3 - 10m (Depending on lightning conditions)
Delivery content
  • Intel RealSense D415 Depth Camera
  • Tripod
  • USB-Cable
HAN: 82635ASRCDVKHV
Shipping weight: 0,30 Kg
Product weight: 0,29 Kg
Average product review
