Software
Technical Details
- IntelŪRealSense™ Vision Processor D4
- up to 1280 x 720 depth Resolution
- up to 1920 x 1080 RGB-Resolution
- FOV: 90°
- two global shutter sensors for streaming up to 90 Pictures/Sec.
- Range: 0,2 - 10m (Depending on lightning conditions)
- integrated IMU with 6DOF#s
- Intel RealSense D435i Depth Camera
- Tripod
- USB-Cable
HAN: | 82635D435IDK5P |
Shipping weight: | 0,31 Kg |
Product weight: | 0,20 Kg |
