Software
Technical Details
- IntelŪRealSense™ Vision Processor D4
- up to 1280 x 720 depth Resolution
- up to 1280 x 800 RGB-Resolution
- FOV: 90°
- two global shutter sensors for streaming up to 90 Pictures/Sec.
- RGB Global Shutter frames up to 90 Pictures/Sec.
- Range: 0,4 - 10m (Depending on lightning conditions)
- integrated IMU with 6DOF#s
Delivery content
- Intel RealSense D455 Depth Camera
- Tripod
- USB-Cable
HAN: | 82635DSD455 |
Shipping weight: | 0,38 Kg |
