Intel® RealSense Depth Modul D415
Item number: MBS-SES-144
Intel® RealSense™ Depth Module D415 (BULK)
  • Intel®RealSense™
  • up to 1920 x 1080 RGB resolution
  • diagonal field of view over 70°
  • two global shutter sensors for depth streaming at up to 60 frames/s
  • range 0.3 m to over 10 m (varies depending on lighting conditions)
  • 50pin connector
Category: 3D Machine Vision
Price on application
Available now!
Software
Technical Details
  • Intel®RealSense™
  • 50 pin connector
Delivery content
  • Intel RealSense Depth Module D415 (BULK)
Average product review
Intel® RealSense Depth Modul D415 Datasheet
