Software
Technical Details
- Intel®RealSense™
- up to 1280 x 720 passiv stereo depth resolution
- diagonal field of view over 70°
- two global shutter sensors for depth streaming at up to 30 frames/s
- range 0.3 m to over 10 m (varies depending on lighting conditions)
- 50 pin connector
Delivery content
- Intel RealSense Depth Module D420 (BULK)
