IntelŪ RealSense Depth Modul D450
Item number: MBS-SES-147
IntelŪ RealSense™ Depth Module D415 (BULK)
  • IntelŪRealSense™
  • up to 1280 x 800 RGB resolution
  • two global shutter sensors for depth streaming at up to 30 frames/s
  • range 0.2 m to over 10 m (varies depending on lighting conditions)
  • 50pin connector
Category: 3D Machine Vision
Price on application
Available now!
Software
Technical Details
  • IntelŪRealSense™
  • 50pin connector
Delivery content
  • Intel RealSense Depth Module D450 (BULK)
Average product review
IntelŪ RealSense Depth Modul D450 Datasheet
