Inventables X-Carve 1000mm Laser Bundle
Item number: MBS-IN-11
Inventables X-Carve - Laser Bundle
  • "Fully Loaded"
  • Working area: 750mm x 750mm x 65mm
  • DeWalt spindle: 16 000 - 27 000rpm
  • Tolerances: > 0,075mm
  • Incl. 6W Laser-Upgrade by OptLaser
Category: CNC Milling
starting from 3.799,00 €
Available now!
Shipping time: 1 - 4 workdays
The Inventables X-Carve is an easy to set up and operate GRBL supported CNC milling machine with a maximum milling area of 750mm x 750mm x 65mm with a tolerance of only 0.075mm. In combination with a DeWalt milling spindle, where the speed can be adjusted between 16 000 rpm and 27 000 rpm, the X-Carve allows the machining of wood, plastics and soft metals such as aluminium.
Special Features
Due to the integrated automatic leveling function, a very well adjusted X-Carve CNC milling machine can reach tolerances of up to 0.075mm. The user is supported by the software, which makes the handling of the machine easy even for inexperienced users.
In addition, the powerful DeWalt spindle enables the machining of different materials with a maximum size of 750 x 750 x 65mm. The list of materials to be machined includes Wood, aluminium, various plastics, such as PP, PC, ABS, PA6 and many more, as well as leather and PCB's/PCB's As a result, the X-Carve is already enjoying many enthusiastic customers from very different industries.
The inventory is controlled by the so-called X-Controller, which is based on a GRBL firmware, and in combination with the very user-friendly Easel CAM software rounds off the system. Easel was also developed by the developers of the X-Carve and is therefore perfectly adapted to the CNC milling machine. Furthermore, no previous knowledge of subtractive manufacturing methods is necessary. The graphical interface guides the user through all parameters to be configured and suggests recommended values.
Last but not least is the large variety of materials, which makes the X-Carve so popular. Thus, in addition to the usual soft materials, such as various woods and plastics, metals such as copper, aluminum & brass can be processed with very high precision. In addition to the right milling cutter, attention must also be paid to the appropriate feed rates and traverse speeds, but should not be a problem for the experienced user.
PLH3D-6W Laser upgrade for your Inventables X-Carve
This engraving laser head has been specially developed for industrial applications. The PLH3D-6W features a very robust design and is compatible with all types of control signals used in CNC applications. In addition, a wide range of power supplies can be used as well as the most powerful fans available for this size. To change the focus distances, a lens adjustment tool is also included.
Delivery Content
Inventables X-Carve 1000mm Fully Loaded
  • X-Carve Base & Hardware
  • Rail Kit
  • DeWalt 26200 Spindle
  • X-Controller Kit
  • Nema 23 Motors Kit
  • Waste Board
  • Drag Chain
  • Toolkit
  • Homeing Kit
  • Z-Probe Kit
  • Side Board
  • Dust Control System
  • Clamp Set
  • Digital Calipers
  • 1 Year Easel Pro Software
Shipping weight: 47,00 Kg
Product weight: 40,00 Kg
Average product review
Manual
Inventables X-Carve 1000mm Datasheet
This product consists of
2.669,95 € *
Available now!
Inventables X-Carve 6W Laser upgrade PLH3D-6W
949,95 € *
Available now!
