Inventables X-Carve 15W Laser upgrade PLH3D-15W
Item number: MBS-OPT-03
EAN: 5902693111689
Inventables X-Carve PLH3D 15W Upgrade Kit
  • 15W diode laser
  • Simple installation
  • Magnetic holder for the laser
Category: Factory
Price on application
Available now!
PLH3D-15W Laser Upgrade for your CNC Milling Machine
The latest model of the insutial cutting and engraving laser head from the PLH3D series, is by far the most versatile on the CNC market. With its 15W powerful laser as well as the new design, this laser head is able to process various materials such as wood, textiles, plastics or even leather. Thanks to its high power, this laser can engrave metal deeply, this feature is probably still unique on the market. The blue laser light also allows for a much more efficient processing of materials than infrared lasers. In addition, the PH3D series lasers can be adapted to any CNC machine. For industrial applications, this lightweight, powerful, cost-efficient and easy-to-use laser is an ideal choice.
Product Features
Unmatched optical performance in its class - Uses multiple high power blue laser diodes to scale optical power. Powered by blue laser diodes - Unlike infrared light, blue light is more easily absorbed by many industrial materials. This leads to a number of benefits, including lower power consumption and more compact heat dissipation. Precision Aspherical Lenses - Each laser module contains four precision-molded lenses, each of which is virtually defect-free. Combined with a vacuum sputtered multilayer anti-reflective coating, this design provides superior optical performance and a spectacular power density of 1.5 MW/cm². Synergy of power and narrow beam spot - The optical system bundles the beams from multiple high-power laser diodes and focuses them to a narrow spot. The result is a high power density that enables engraving of a wide variety of materials such as stainless steel, tool steel and titanium. Lightweight design for mounting on virtually any CNC machine - The lightweight aluminum housing makes the laser weigh less than 800 g. Since a typical CNC spindle weighs about 1.8 kg, CNC machines can operate it with ease. Easy integration - Can be set up on almost any CNC machine as it accepts both analog and PWM CNC signals. Instant start-up - No warm-up time. High pressure air nozzle eliminates high maintenance - With the high pressure air nozzle, you can clean the lens 10x less often. The compressed air also speeds up the cutting and engraving process by removing smoke and preventing excessive dirt buildup on the lens. In addition, the directional airflow cools the work area, resulting in a lack of defects and consistent engraving contrast. Integrated Control Electronics - To prevent premature death of your laser diodes, the control electronics are integrated into the laser module. With no redundant wiring, you don't have to worry about dangerous inductance effects. Longer life - Blue laser diodes have a longer life because they do not suffer from random failures and age more slowly at higher temperatures. The typical lifetime of laser blue diodes is equivalent to 20,000 hours. In contrast, the life of an average glass CO2 tube laser cutter and engraver is 3,000 hours.
Important note: this laser is a third party device, for support requests please contact us or directly the manufacturer!
  • Dimensions: 40x54x78mm
  • Focus range: 20-120mm
  • distance to the object @ 30mm: 0,1x0,1mm
  • distance to object @ 55 mm: 0,1x0,125mm
  • distance to object @ 80 mm: 0,1x0,3mm
  • operating voltage: 12-24V -Loudness: 58 dBA
  • Weight: 410g
  • Mounting hole: M3x0,5x4,5mm
  • Working temperature: 0 - 45°C
  • Maximum power 30W
About the PLH3D-CNC adapter
The main function of the PLH3D-CNC adapter is to "arm" and "disarm" the laser head. Arming means turning on the power supply to the head; the armed head is then able to use its laser. Disarming turns off the power supply, making it impossible to continue using the laser. The built-in safety device can prevent misoperation and unexpected behavior in emergency situations. The key switch protects the laser from children and other unauthorized to use it. The user can manually configure the laser head at any time by pressing a button. The special circuitry can prevent the internal electronic devices from being armed in the event of your malfunction. In an emergency, the laser head is automatically disabled: The power supply is interrupted, the power supply fails and the laser head cable is interrupted or disconnected. After deactivation, the system is still in a safe state. When deactivating again, the user must always press a key.
Important features of the PLH3D-CNC adapter
  • Softstart
  • indicator LEDs - power, armed, laser in operation
  • built-in microcontroller -
  • x programmable enable inputs
  • 2x external safety terminals (e.g. safety button, emergency stop)
  • Automatic disarming after power off
  • One second laser button
  • Compatibility with PLH3D laser heads
  • Key lock to prevent use by unauthorized persons
  • On button system (for arming)
  • PLH3D-15W laser head
  • PLH3D-CNC adapter
  • Laser safety glasses
  • Power supply
  • PLH3D-CNC adapter cable for the laser head
  • CNC machine to PLH3D-CNC adapter signal cable
CAUTION!
  • Remember that this is not a toy.
  • Laser radiation is dangerous even if scattered or reflected from any surface
  • Always use an appropriate laser safety filter on your CNC machine for 430 - 480 nm to avoid reflected radiation.
  • Never point the laser head at people or animals.
  • Do not touch the beam, it can cause burns or other injuries.
  • Do not stare into the beam or beam spot while cutting material.
  • Avoid contact of eyes and/or skin by direct or scattered radiation.
  • This is a Class 4 laser product.
Average product review
General Informations
