Marvelmind Modem Outdoor
The Marvelmind Modem is one of two parts that enable a very precise indoor navigation with a tolerance of only 1-3% / ±2cm, the other part that is required, is the Marvelmind Beacon. The system is designed to precisely make out the position of both UAV's & AGV's, but also of other objects that have a beacon attached to it. The Marvelmind system is based on an 433MHz radio frequency combined with the latency of ultrasonic sensors.
Special Features
- 3D Positioning if 3 Beacons are used
- 2D Positioning if 2 Beacons are used
- Recommended Distance 30m | capable of up to 50m
Technical Data
- Space: < 1000m²
- Latency: ±2cm
- Localisation speed: 0,05 - 45Hz
- Interfaces: UART, USB & I2C
- 1 x Outdoor Modem incl. Antenna
The user manual, configuration exemples aswell as additional technical data can be found HERE.
HAN: | 4680038530371 |
Shipping weight: | 0,07 Kg |
Product weight: | 0,02 Kg |
