Marvelmind Super Beacon 868/915MHz + IMU
The Marvelmind Beacon is one of two components that enable a very precise indoor navigation with a tolerance of only 1-3% /
±2cm, the other part that is required is the Marvelmind modem. The system is designed to precisely make ou the position of both UAV's & AGV's, but also of other objects that have a beacon attached to it. The Marvelmind system is based on an 868MHz/915MHz frequency combined with the latency of ultrasonic sensors.
Special Features
- 3D Positioning if 3 Beacons are used
- 2D Positioning if 2 Beacons are used
- Recommended Distance 30m | capable of up to 50m
- Integrated IMU
Technical Data
- Space: < 1000m²
- Latency: ±2cm
- Localisation speed: 0,05 - 25Hz
- Working Voltage: 1000maH Lipo
- Weight: 59 Grams (incl. Battery, Antenna and Case - without 27g)
- Dimensions: 55 x 55 x 33mm
incl. Antenna: 55 x 55 x 65mm
- 1 x Super Beacon + IMU incl. Antenna
HAN: | 4680038530654 |
Shipping weight: | 0,08 Kg |
Product weight: | 0,06 Kg |
