Original USBasp 2 ISP Programmer
Item number: MBS-Z-12
Original USBasp 2 Programmer
  • Windows / Linux / Mac compatible
  • 6 & 10 Pin ISP Plug
  • 3,3 & 5V Output Voltage
  • fast start-up
  • controllable Upload Speed
Category: Accesoires
IDC10 Breadboard Connector
starting from 14,95 €
including 16% VAT. , plus shipping
Available now!
Shipping time: 2 - 4 workdays
The USBASP Programmer is an adapter that is used for programming and fits to all current Atmel Microcontroller. Due to the compact design and the easy comissioning the USBASP Programmer is used by a huge community. If Linux or Mac is used there is no need of any additional driver, only when using Windows the driver packages have to be installed either manually or via Zadig. The USBASP Programmer can be used with a variety of development enviroments such as Arduino, Bascom or AVRDUDE and many more. The voltage supply and the speed of data transmission to the uC can be controlled via Jumper.
  • 3,3 & 5V Voltage Output
  • 6 & 10 Pin ISP Header
  • Integrated 500mA fuse to protect the USB Port
  • Upload Speed up to 5kB/s
  • Two Status LED's
The IDC10 Breadboard Connector wich is optionally available allows the USBASP Programmer to be attached to an breadboard in a test arrangement
Supported Microcontroller / Microprocessors
    ATmega8, ATmega88, ATmega8515, ATmega8535, ATmega128, ATmega1280, ATmega1281, ATmega16, ATmega161, ATmega162, ATmega163, ATmega164, ATmega103, ATmega32, ATmega324, ATmega329, ATmega3290, ATmega48, ATmega64, ATmega640, ATmega644, ATmega649, ATmega6490, ATmega168, ATmega328
    ATtiny12, ATtiny13, ATtiny15, ATtiny2313, ATtiny24, ATtiny25, ATtiny26, ATtiny45, ATtiny84, ATtiny85
    AT90S2313, AT90S2333, AT90S1200, AT90S2343, AT90S4414, AT90S4433, AT90S4434, AT90S8515, AT90S8535, AT90USB646, AT90USB647, AT90USB1286, AT90USB1287, AT90PWM2, AT90PWM2B, AT90PWM3, AT90PWM3B, AT90CAN32, AT90CAN64, AT90CAN128
    Delivery content
    • Original USBasp 2 Programmer
    • 50cm 10 Pin ISP Data Cable
    • 30cm 6 Pin ISP Data Cable
    • Optional IDC10 Connector
    Average product review
    Other customers have also bought the following items
    CNC Board Pololu Sockets
    10,95 € *
    Available now!
    Raspberry Pi CNC Board
    starting from 48,95 € *
    Available now!
    DYNAMIXEL XL430-W250-T
    48,95 € *
    Available now!
