Pixhawk PX4 GPS Module
Item number: MBS-SES-24
Pixhawk GPS Module
  • Pixhawk PX4 compatible
  • Small dimensions
  • Light weight (32g)
Category: Sensor Systems
58,95 €
Available now!
Shipping time: 2 - 4 workdays
This new design incorporates the HMC5883L digital compass, using the Ublox latest 8series module providing a convenient method of mounting the compass away from sources of interference that may be present in the confines of the vehicle. It features active circuitry for the ceramic patch antenna, rechargeable backup battery for warm starts. The units ship pre-configured for use with Pix32.
The NEO-M8 series of standalone concurrent GNSS modules is built on the exceptional performance of the u-blox M8 GNSS GPS, GLONASS, Galileo, BeiDou, QZSS and SBAS) engine in the industry proven NEO form factor. The NEO-M8 series provides high sensitivity and minimal acquisition times while maintaining low system power. The NEO-M8M is optimized for cost sensitive applications, while NEO-M8N and NEO-M8Q provide best performance and easier RF integration. The NEO form factor allows easy migration from previous NEO generations.
Sophisticated RF-architecture and interference suppression ensure maximum performance even in GNSS-hostile environments.
The NEO-M8 combines a high level of robustness and integrationcapability with flexible connectivity options. The future-proof NEO-M8N includes an internal Flash that allows simple firmware upgrades for supporting additional GNSS systems. This makes NEO-M8 perfectly suited to industrial and automotive applications. The DDC (I2C compliant) interface provides connectivity and enables synergies with most u-blox cellular modules. For RF optimization the NEO-M8N/Q features an additional front-end.
LNA for easier antenna integration and a front-end SAW filter for increased jamming immunity.
This module will be shipped with a baud rate of 38400, 10Hz.
Pixhawk GPS & PX4
A quick start guide for the use of the GPS module in combination with the Pixhawk PX4 Drone & UAV Controller can be visited HERE.
Specifications
  • Industrial sensitivity (-167 dBm)
  • Cold start < 26 sec.
  • Rechargable 3V Lithium battery
  • Low noise 3,3V regulator
  • 60mm Diameter
  • 32g with Case
  • 30cm Pix32 24 compatible 6 Pin
  • APM 5 Pin 2 types compatible
Accessories
For a better use and a higher reliability every Pixhawk PX4 GPS Moudle will be shipped with some additional components to mount the module on a higher position of the UAV/Drone.
Delivery Content
  • Neo M8N GPS Module
  • Accessories
Product weight: 0,07 Kg
Average product review
Contact
Pixhawk GPS & PX4 Guide
Other customers have also bought the following items
189,95 € *
Available now!
Pixhawk PX4 Cable Set
14,95 € *
Available now!
Pixhawk PX4 Power Module PM07
34,95 € *
Available now!
