Pixhawk PX4FLOW v1.31
Item number: MBS-ENTB-25
EAN: 0096718604357
Pixhawk PX4FLOW v1.31 Optical Sensor
  • Indoor & Outdoor
  • 752 x 480 Pixels
  • Image processing with 400Hz
  • USB Serial Baudrate with up to 921600
Category: Electronics
137,95 €
Not available now!
PX4Flow is an optical flow smart camera. It has a native resolution of 752×480 pixels and calculates optical flow on a 4x binned and cropped area at 250 Hz (bright, outdoors), giving it a very high light sensitivy. Unlike many mouse sensors, it also works indoors and in low outdoor light conditions without the need for an illumination LED at 120 Hz (dark, indoors). It can be freely reprogrammed to do any other basic, efficient low-level computer vision task.168 MHz Cortex M4F CPU (128 + 64 KB RAM) 752×480 MT9V034 image sensor, L3GD20 3D Gyro 16 mm M12 lens (IR block filter) Source code will be available shortly, comes with planar flow for position hold programmed.
You will need for the first use of the PX4Flow, a UAV/Flight Controller like the Pixhawk PX4 Controller, too. Furthermore the QGroundControl Tool will be required to adjust the lense. Further informations and instructions can be read HERE.
Specifications
  • 168MHz Cortex M4F MCU mit 128 + 64KB RAM
  • 752 x 480 MT9V034 Bildsensor 400Hz
  • L3GD20 3D Gyro
  • 45,5 x 35mm
  • Current: 115mA at 5V
  • USB Serial with 921600 baud
  • Pixhawk PX4FLOW Camera Sensor Modul
HAN: 19001
Product weight: 0,05 Kg
Average product review
Contact
Other customers have also bought the following items
Pixhawk PX4 Drone & UAV
313,95 € *
Not available now!
TFmini-S LiDAR Benewake 12m
42,95 € *
Available now!
Pixhawk PX4 Cable Set
15,95 € *
Available now!
Pixhawk PX4 2.nd GPS Module
65,95 € *
Available now!
Pixhawk Digital Airspeed Sensor
72,95 € *
Available now!
Pixhawk 2.1 Cable Set
18,95 € *
Available now!
