Cookie hint
We are using cookies to supply our services. If you use our services, you agree the usage of cookies
x
RPLIDAR A2 360° Laser Scanner
Item number: MBS-ELEK-SES-13
RPLIDAR A2M8 360° Laser Scanner Development Kit
  • Distance Range 0,15 - 12m
  • Distance Resolution <1%
  • Scan Rate 10Hz
  • Power 1,5A / 5V
  • Rotation Speed 600RPM
Category: Electronics
389,00 €
including 19% VAT., plus shipping
Available now!
Shipping time: 2 - 4 workdays
The RPLIDAR A2M8 360° Laser Scanner is the next generation of 360 degree 2D lidars. The RPLIDAR A2 adopts low cost laser triangulation measurement system developed by SLAMTEC, and therefore has excellent performance in all kinds of indoor environments and outdoor environments without direct sunlight exposure.
It can take up to 8000 samples of laser ranging per second with high rotation speed. And equipped with SLAMTEC patented OPTMAG technology, it breakouts the life limitation of traditional LIDAR system so as to work stably for a long time.
  • Up to 10Hz 8000 Points
  • Free SDK / Environment
  • Full ROS Support
  • Low Noise Brushless Motor
  • Ultra-long life 5 years / 24h
Interfaces
The RPLIDAR A2 has a RS232 and USB connection. Please take a look at the subjacent picture.
Laser und Scan Rate
Specifikations
Model: RPLIDAR A2M8
Distance Range: 0,15 - 12m
Angular Range: 0 - 360 degree
Distance Resolution: <1%
Sample Duration: 0,25 millisecond
Sample Frequency: 8000Hz
Scan Rate: 10Hz
Requires at least: 1,5A & 5V
Weight: 340g
Software and documents
Ratings (0)
Average product review
Product Tags
Other customers have also bought the following items
