RPLIDAR A2M6 360° Laser Scanner (Range: 18m)
Item number: MBS-SES-14
RPLIDAR A2M6 360° Laser Scanner Development kit
  • Measurement range 0,15 - 18m
  • Accuracy <1%
  • Scan Rate 10Hz
  • Power consumption 1,5A / 5V
  • Sample Frequency 600RPM
Category: Electronics
466,95 €
including 16% VAT. , plus shipping
Available now!
Shipping time: 2 - 4 workdays
General
The RPLIDAR A2M6 Laser Scanner is the more enhanced Version of the 2D Lidar. The measurement system that is manufactured by SLAMTEC  is suitable for both Indoor and Outdoor applications. The RPLIDAR has a high rotation speed and is capable of up to 8000 measurements per second.
The  RPLIDAR A2 360° Laser Scanner is provided with 600RPM and a resolution of up to 1°. An example of a possible Point Cloud can be seen below.
  • Up to 10Hz with 8000 Measurements
  • free SDK / development enviroment
  • Full ROS support
  • Low Noise due to Brushless Motor
  • Ultra-long life 5 years / 24h
Evaluation of the measurement data
The evaluation of the acquired data can be done via RS232 or USB. The picture below shows the XH2.54-5P Plug that is lead out of the case of the A2 RPLIDAR. The delivery content also contains an module that can be used to enable the connectivity to USB.
Laser and Scan Rate
Model: RPLIDAR A2M6 Distance Range: 0,15 - 18m Angular Range: 0 - 360 degree Distance Resolution: <1% Sample Duration: 0,25 millisecond Sample Frequency: 8000Hz Scan Rate: 10Hz Requires at least: 1,5A & 5V Weight: 340g
Software and Documents
HAN: 110991067
Shipping weight: 0,41 Kg
Product weight: 0,20 Kg
Average product review
