Robotiq's vacuum gripper is a low-noise plug&play solution. which is fully customizable and has a fast response time. The vacuum gripper can be used in a wide range of applications. It is ideal for picking up (in)regular workpieces made of different materials (cardboard, sheet metal (dry), glass and plastic). Due to the adjustable holder and the unique air knots, complete control over the gripper is achieved. It was developed for collaborative robots. Helpful here is also the smooth integration with Robotiq's wrist camera and FT300 force/torque sensor. For industrial requirements, it has several advantages: industrial-grade components, low maintenance and payload, which depends on the cobot.
The gripper is available in two versions: EPick and AirPick
Easy integration and commissioning
- No background knowledge required
- can be installed in a few minutes using the Plug&Play kit
- with URCap software: guarantee for optimal configuration of the gripper for the specific application
- no external air supply necessary
- the air nodes connect the air hoses to the suction cups
EPick
The EPick vacuum gripper is connected to the Cobot wrist. It is easy to use and does not require an air supply.
- Energy source: electricity
- gripper mass: 10g
- Vacuum level: 80%
- Vacuum flow: 12 l/min
- Noise level: 64dB (A)
All technical data can be found in the data sheet.
AirPick
The AirPick has a high flow rate of compressed air, generates little noise and has a compact design for the cobots.
- Energy source: compressed air
- Gripper mass: 323g
- Vacuum level: 85
- Vacuum flow: 81,5 l/min
- Noise level: 70,5dB (A)
- Air consumption: 135,9 l/min
- Robotiq vacuum gripper
