Duripod Astra Embedded S
  • Codice articolo: MBS-Z-127
  • Filtra: 0096718607211
  • #global.han#: Duripod for Embedded S
The DuriPOD for the Embedded S:
  • is a protective housing for the camera
  • is slim but robust
  • has a Corning glass lens
  • has an Al Alloy ADC12 metal frame
  • supports the heat dissipation of the camera
The DuriPOD for the Embedded S is a protective device for your camera. The DuriPOD is slim but can withstand a lot, making it suitable for any project. The Corning glass lens and sturdy Al alloy ADC12 metal frame protects against mean wear and tear. In addition, the heat dissipation of the camera is not hindered in any way, but supported.
Technical data:
  • Dimensions: 94.5 x 32.5 x 28 mm.
  • Housing material: AL alloy ADC12
  • lens cover: soda-lime glass
  • Connections: 1/4 inch 20 UNC
Scope of delivery:
  • 1x thermal pad (20 x 20 x 1.0 mm)
  • 1x tripod (1/4-20 black
  • 2x screws for backplate (M2.0*4, SWCH1018A)
  • 4x screws for Embedded S (M1.6*4, SWCH1018A)
€ 54,95
