Stereolabs ZED X Mini 50mm Stereo Camera 2.2mm with Polarization Filter
  • SKU: MBS-SES-300-03
  • GTIN: 0618455050343
  • HAN: ZED-311220
  • Category: Sensors
Stereolabs ZED X mini Stereo Kamera
  • Powerful IMU
  • IP66 protected
  • Multi-camera synchronization
  • Global Shutter with 1200p 60fps
  • Neural Depth Gen2
  • GMSL2 connector
The highest level of perception
The new ZED X is an IP66-certified robotic global shutter camera based on the Neural Depth Engine2. With its rugged aluminum housing, powerful IMU, secure GMSL2 connectivity and external image synchronization, it is ready for immediate use in the field. To top it off, the ZED X has a frame rate of Up to120fps at 960x600 and a pixel size of 3μm. Capture every movement without sacrificing even a hint of dynamic range or image quality thanks to the global shutter. No blurry or curved lines. Just perfect pixels in every scene.
Global shutter with 1200p 60fps
With dual 1920x1200 resolution global shutter color sensors, the camera produces crystal-clear images to quickly capture any busy environment.
Powerful IMU
The all-new IMU combines a triaxial 16-bit accelerometer and gyroscope with vibration resistance, ultra-low noise and bias for exceptional motion tracking.
Neural Depth Engine 2
Stereolabs' Neural Depth Engine 2 enables 50% more accurate depth maps and is robust to unstructured surfaces and lighting conditions, from 10 cm to tens of meters.
Secure GMSL2 connection
GMSL2 output is ideal for robotics. Transmit video without EMI through a robust interface to a Jetson Orin over distances up to 15 meters with low latency.
Industrial grade housing
The rugged IP66 enclosure is perfect for industrial environments. It provides protection against dust and water ingress, which is essential for mobile robots.
Hardware synchronization for multiple connected devices at frame level within 100 microseconds. Capture multiple RGB and depth images of the same scene, all aligned.
Attention
The ZED X can only be used with the Capture Card (selectable in the dropdown) or the ZED Box.
  • 1x ZED X MINI (only)
Shipping weight: 0,50 kg
Item weight: 0,41 kg
PDF (3)
Stereolabs ZED 2 Datasheet
Stereolabs ZED2 ROHS
Focal length
Polarization
€ 879,99
