Luxonis OAK-D Short Range PoE
Luxonis OAK-D SR PoE
  • IR Dot Projector
  • Time-of-Flight (ToF) VGA (640x480 @ 30fps)
  • Two OV9782 (1 MP Color Global Shutter)
  • IP67 certified enclosure
The OAK-D SR PoE is a camera that emphasizes improved short-range accuracy compared to the standard OAK-D and further expands our range of solutions for robotic image processing. It uses a Time-of-Flight (ToF) VGA sensor that enables accurate measurement of the depth of objects in a scene, leading to more precise focusing and improved performance in low-light conditions.
Specifications:
  • IR dot projector
  • Time of Flight (ToF) VGA (640x480 @ 30fps)
  • IP67-rated enclosure
  • M12 X-coded connector
  • M8 IO connector
  • PoE circuitry
In the Box:
  • 1x OAK-D SR PoE
  • 1x M12 plug to RJ45 cable, 2m
Note: ToF sensor decoding isn't fully implemented, so the depth from TOF isn't accurate. It will be implemented in firmware in November, allowing users to update the library to get the improved depth from it.
€ 549,95
Others also bought:
