Movella MTi-7-5A GNSS/INS Development Kit
  • SKU: MBS-MOV-02
  • GTIN: 0658917501495
  • HAN: MTi-7-5A-DK
  • Interface SPI / I2C / UART / micro USB
  • Weight: 16g,
  • 2000deg/s Dev.Board+module + GNSS receiver
Discover the MTi-7 - the ultimate GNSS/INS (Global Navigation Satellite System/Inertial Navigation System) for precise and reliable positioning. With an impressive synchronization function, the data from the built-in accelerometer, gyroscope and magnetometer can be seamlessly connected to an external GNSS receiver.
Thanks to its advanced signal processing technology, the raw sensor signals are processed in real time at an impressive 100 Hz data rate. This creates a continuous stream of data that gives you the precise 3D position, velocity and orientation of the device.
Part of the highly acclaimed MTi 1 series, the MTi-7 sets the standard for size and weight. At just 12.1 × 12.1 mm, it is one of the most compact modules on the market. It also weighs less than 1 g, making it an ideal choice for applications where every gram counts. Rely on the MTi-7 to maximize the performance of your GNSS/INS systems.
With its precise data processing, seamless integration of sensor signals, and remarkable compactness, the MTi-7 is the ideal solution for a wide range of applications, including navigation systems, robotics, drones, autonomous vehicles, and more.
Specification
  • IP protection class (equivalent): IP00
  • Dimensions 12.1 × 12.1 × 2.55 mm
  • Weight 0.6 g
  • Electrical Input voltage: 2.8 to 3.6 V
  • Power consumption (typ.): <150 mW @ 3 V
  • Interfaces / IO Interfaces: UART, SPI, I²C
  • Protocols: Xbus, NMEAin
  • Output frequency: up to 1 kHz
  • 1x Movella MTi-7-5A GNSS/INS Development Kit
Shipping weight: 1,00 kg
Item weight: 0,60 kg
Datasheet
€ 654,95
