Intel® RealSense Depth Camera D435f
- SKU: MBS-SES-258
- Category: 3D Machine Vision
Manufacturers:
Intel® RealSense™ Depth Camera D435
- Intel®RealSense™ Vision Processor D4
- IR pass filter
- up to 1280 x 720 active stereo depth resolution
- up to 1920 x 1080 RGB resolution
- diagonal field of view over 90°
- two global shutter sensors for depth streaming at up to 90 frames/s
- range 0.2 m to over 10 m (varies depending on lighting conditions)
Software
Thanks to IR now with improved depth quality
The Intel® RealSense™ D435f depth camera expands the RealSense portfolio for the growing autonomous mobile robot market. The IR pass filter significantly improves the quality of depth noise, as well as the performance range for many robotic environments.
- IR pass filter
- up to 1280 x 720 depth Resolution
- up to 1920 x 1080 RGB-Resolution
- FOV: 90°
- two global shutter sensors for streaming up to 90 Pictures/Sec.
- Range: 0,2 - 10m (Depending on lightning conditions)
- USB-C* 3.1 Gen 1 connector
- Dimensions 90 * 25.8 * 25 mm
- Intel RealSense D435 Depth Camera
| Item information | Value |
| Shipping weight: | 0,31 kg |
