Luxonis OAK 4 D Fixed Focus
- SKU: MBS-SES-359-02
- GTIN: 0658917514433
- HAN: OAK-4-D-FF
- Category: 3D Machine Vision
Manufacturers:
OAK 4
- Version: D
- 8-core ARM CPU (QC Snapdragon 8 series), 8GB RAM, 128GB storage
- Powered by Luxonis OS, based on Linux Kernel 5.15
- Computer Vision: Warp (undistorted), resizing, cropping via ImageManip nodes, edge detection, feature tracking. Also supports custom CV functions
- AI Performance: 48 TOPs (INT8) and 12 TOPs (FP16) operations
- Stereo depth perception with filtering, post-processing, RGB-depth alignment, and high configurability
- Object tracking: 2D and 3D tracking with ObjectTracker node
OAK 4 Features
- Versions: S, D, D Pro
| Auto Focus | Fixed Focus | Wide | Stereo Pair | Stereo Pair - Wide | |
| Sensor | IMX586 (PY237) | IMX586 (PY261) | IMX586 (PY262) | OV9282 (PY238) | OV9282 (PY265) |
| DFOV | 82.4˚ | 82.4˚ | 120.0˚ | 84.5° | 149.2° |
| Max resolution | 48MP (8000x6000) | 48MP (8000x6000) | 48MP (8000x6000) | 1MP (1280x800) | 1MP (1280x800) |
| Focus | AF | FF | FF | FF | FF |
| Max Framerate | 480 FPS | 480 FPS | 480 FPS | 60 FPS | 60 FPS |
| Spectral range | Visible | Visible | Visible | Visible | Visible |
| Shutter Type | Rolling | Rolling | Rolling | Global | Global |
| Sensor size | 1/2" | 1/2" | 1/2" | 1/4" | 1/4" |
| F-number | 1.79 ± 5% | 1.79 ± 5% | 1.79 ± 5% | 2.0 ± 5% | 2.0 ± 5% |
| Effective Focal Length | 4.74mm | 4.74mm | 4.74mm | 2.35mm | 1.69mm |
| Pixel size | 0.8µm | 0.8µm | 0.8µm | 3.0µm | 3.0µm |
OAK 4 D – Advanced Edge Computing and Stereo Vision Camera
The OAK 4 D is a standalone camera unit specifically designed for robotic vision and automated systems. It combines a high-resolution RGB camera with a stereo depth camera, enabling precise environmental perception through powerful on-device AI inference and computer vision technology.
Key Features
Integrated RVC4 Technology:
- 8-core ARM CPU (QC Snapdragon 8 series) with 8 GB RAM and 128 GB storage
- Operating system: Luxonis OS based on Linux kernel 5.15
- Computer vision functions: image undistortion, resizing, cropping via ImageManip node, edge detection, feature tracking, and support for custom CV functions
- AI Performance: 48 TOPs (INT8) and 12 TOPs (FP16) for fast and efficient AI inference
- Stereo depth perception: includes filtering, post-processing, RGB-depth alignment, and extensive configurability
- Object tracking: 2D and 3D tracking via the ObjectTracker node
Technical Specifications
- Baseline distance: 75 mm
- Optimal depth range: 70 cm – 12 m
- Power consumption: Up to 25 W
Housing:
- Rugged aluminum with Gorilla Glass front cover
- Water-resistant enclosure with IP67 certification
Mounting options:
- 1/4" tripod mount
- 75 mm M4 VESA mount on the back and bottom
- Dimensions: 143.5 × 42.5 × 67.3 mm
- Weight: 674 g
- 1 OAK 4 D FF
- M12 plug to RJ45 cable, 2m
| Item information | Value |
| Shipping weight: | 0,80 kg |
| Item weight: | 0,67 kg |
