Orbbec3D Embedded S
  • SKU: MBS-SES-49
  • GTIN: 0096718605101
  • HAN: AstraES2019
  • Category: Sensors
Orbbec3D Astra Embedded S 3D-Camera
  • 1920 x 1080 Pixel
  • Depth Images up to 60FPS
  • Scan range: 0,25 - 1,5m
  • USB Type-C Port
The Orbbec3D Embedded S is a very small 3D-Camera with a high picture resolution of 1920 x 1080 Pixel at 30FPS. The depth resolution framerate is 1280 x 720Px /  640 x 400Px at 60FPS. The acquired data can be used in multiple ways via the USB Port Type-C. Below are some of the current fields of application listed, that the Orbbec3D Embedded S finds it use :
  • Robotic / Autonomous systems
  • Quality check
  • 3D-Scanner / Full Body Scanner & Handheld
The large spectrum of possible applications is only achievable through the outstanding hardware aswell as well-engineered software and driver packages that also result in the Orbecc Embedded S to be compatible with ROS, OpenNI2, Astra SDK and much more.
The whole sortiment of Orbbec3D software products such as the Windows or Linux driver, the Orbbec3D Unity Engine, or the Body Tracking SDK can be downloaded for free and without any registration needed using the following link: https://orbbec3d.com/develop/
Special Features of the Orbbec3D Embedded S
The Orbbec3D Astra Embedded S if compared with the Astra Stereo S and Astra Mini has the benefit of a very compact design and a USB 3.0 Port.
  • Depth Images: 1280 x 720Px 30FPS | 640 x 400Px 60FPS
  • RGB Resolution: 1920 x 1080Px
  • FOV: 67,9H 45,3V 78D
  • Dimensions: 68,6 x 22,35 x 14,8mm
  • Scanning range: 0,25 - 1,5m
  • Data transfer & Power: USB Typ-C
  • Power consumption: < 2,2W
  • 1 x Orbbec Astra Embedded S 3D-Camera
Shipping weight: 0,03 kg
Item weight: 0,09 kg
PDF (2)
Orbbec Embedded S Datasheet
Orbbec3D Embedded Brochure
€ 208,95
