Holybro X500 V2 ARF Kit
- SKU: MBS-DR-13
- GTIN: 0096718607181
- HAN: 30125
- Category: Drones
Manufacturers:
The Holybro X500 V2 ARF Kit
- new design
- a very short assembly time, without soldering
- it is perfectly compatible with the Pixhawk5X and the Pixhawk4
The Holybro X500 V2 ARF Kit is a carbon fiber drone kit that can be assembled in a short time (about 15 minutes).
1. X500 V2 frame kit.
- Body: full carbon top and bottom plate (144x144 mm, 2 mm thick).
- Arm: 16 mm carbon fiber tubes with fiber reinforced nylon connectors
- Chassis: 16 mm and 10 mm diameter carbon fiber tubes with improved and reinforced plastic tees
- Platform board: mounting holes for GPS and companion computers like Raspberry Pi 4 and Jetson nano
- dual 10 mm diameter rod
- 250 mm long rail mounting system
- Battery holder (with 2 battery straps)
- hand tool (for installation)
2. X500 V2 ARF Kit
- X500 V2 frame kit
Pre-installed elements ?4x motors - Holybro 2216 KV920 motor.
- 4x controller - BLHeli controller
- 6x 1045 propeller
- Power Distribution Board - XT60 connector for battery & XT30 connector for controller & peripherals.
Mechanical data
- wheelbase: 500 mm
- motor mount pattern: 16x16 mm
- frame body: 144x144 mm, 2 mm thick
- chassis height: 215 mm
- distance between upper and lower plate: 28 mm
- weight: 610 g
| Item information | Value |
| Shipping weight: | 4,00 kg |
| Item weight: | 0,61 kg |
All reviews:
- Goods ordered. 1 expected on 11.12.2026.
Delivery time: 11 - 13 Workdays (DE - int. shipments may differ)
