AgileX Ranger Serie Air/Delta
AgileX Ranger Serie
  • Ranger Air | Ranger Delta
  • 3-wheel / 4-wheel omnidirectional mobile robot
  • Payload: 80kg
  • Hub motor
  • IP22
  • max speed: 1,5 m/s
  • The Ranger Air/Delta offers the same flexible, omnidirectional freedom of movement as the Ranger Mini 3.0, ensuring greater precision and comfort during use.
AgileX Ranger Series – Autonomous All-Terrain Mobile Robot Platform
The AgileX Ranger Series is a powerful autonomous mobile robot platform designed for demanding indoor and outdoor applications. With its robust chassis, all-terrain mobility, and advanced autonomous driving capabilities, the Ranger Series is ideal for research, inspection, logistics, agriculture, industrial automation, and unmanned vehicle development.
The platform features high-performance motors, independent suspension, and differential steering, enabling stable operation on uneven terrain such as gravel, grass, dirt roads, and industrial environments. Its modular design allows easy integration of sensors, robotic arms, LiDAR systems, cameras, GPS modules, and AI computing platforms.
Equipped with autonomous navigation support and multiple communication interfaces, the Ranger Series supports ROS/ROS2 development and can be customized for a wide range of robotic and research applications. The powerful battery system ensures long operating times, while safety functions such as emergency stop and obstacle avoidance support reliable operation in dynamic Environments.
Technical Comparison: AgileX Ranger Air vs. Ranger Delta
Specification RANGER AIR RANGER DELTA Note
Dimensions (L×W×H) 552×500×250 mm 552×500×250 mm Both do not include radar altitude
Weight 50–55 kg 45–50 kg
Max. Speed 1.5 m/s 1.5 m/s
Ground Clearance 39 mm 39 mm
Min. Turning Radius 0 mm (Self-rotation)
680 mm (Ackermann)
680 mm (Ackermann)
Obstacle Clearance 10 mm 10 mm Maximum measured: 30 mm
Ditch Crossing 40 mm 41 mm Maximum measured: 80 mm
Brake Motor Electronic Brake Motor Electronic Brake
Rated Payload 80 kg 80 kg
Max. Climbing Ability 8° (Full load) 8° (Full load)
Max. Travel Distance 25 km 25 km With 80 kg load, the range is approximately 25 km
Motor Hub Motor Hub Motor
Suspension Four-wheel steering, four-wheel drive (rear swing suspension) Three-wheel steering, three-wheel drive (no suspension)
IP Rating IP22 IP22
Operating Temperature 0–45 °C 0–45 °C
Navigation Optional Optional
PS: The above data are based on AgileX Robotics test results under controlled conditions. Results may vary depending on the environment and usage conditions.
  • AgileX Ranger mobile robot platform
  • Integrated battery system
  • Battery charger / power supply
  • Wireless remote controller
  • Integrated motor and drive system
  • Communication interfaces and onboard control system
  • User documentation and software resources
from
€ 3.929,95
  • Must be ordered. Ready for shipment in 10 days after order.
