Orbbec3D Astra Pro Plus
- SKU: MBS-SES-202
- GTIN: 0096718607518
- Category: Sensors
Manufacturers:
Orbbec3D Astra Pro 3D-Camera
- 1920 x 1080PX @ 30FPS
- up to 30FPS
- Scan range: 0,6 - 8m
- Tolerance: 1-3mm
- USB 2.0 Port
The Orbbec3D Astra Pro is a compact 3D-Camera with a picture resolution of 1280 x 720 Pixel at 30FPS. The aqcuired data can be used in multiple ways via the USB Port. Below are some of the current fields of application listed, that the Orbbec3D Astra Pro finds it use:
- Robotic / Autonomous systems
- Quality check
- 3D-Scanner / Full Body Scanner & Handheld
The wide spectrum of possible applications is only achievable through the outstanding hardware aswell as well-engineered software and driver packages that also result in the Orbbec3D Astra Pro to be compatible with ROS, OpenNI2, Astra SDK and much more.
The whole sortiment of Orbbec3D sofware products such as the Windows or Linux driver, the Orbbec3D Unity Engine or the Body Tracking SDK can be downloaded for free without any registration needed using the following link: https://orbbec3d.com/develop/
Who may Need Orbbec Astra ProPlus?
Orbbec Astra is powerful and universal with improved RGB performance.
- for short range 3D scanning -> Astra S
- Sensor with improved RGB performance -> Astra ProPlus
- Sensor with integrated processing unit -> Persee+
- Depth Images: 640 x 480PX @ 30FPS
- RGB / Image Resolution: 1920 x 1080PX @ 30FPS
- FOV: 73D 60H 49.5V
- Dimensions: 165 x 30 x 40mm
- measuring range: 0.6 - 5m
- Two integrated microphones
- Data & Power Supply: USB 2.0
- Power consumption: < 2.5W
- Measuring accuracy: 1m: 1-3mm | 2-3m: 12.7mm
- Operating temperature: 10 - 40°C
- OS: Android, Linux, Windows
- SDK: Astra SDK or OpenNI2 or 3rd party SDK
- 1 x Orbbec Astra Pro Plus
| Item information | Value |
| Shipping weight: | 0,61 kg |
| Item weight: | 0,31 kg |
