DOBOT Magician Sensor Kit
  • Artikelnummer: MBS-SES-392
  • GTIN: 0658917504724
  • HAN: F2311027
  • Kategorie: Sensorik
  • Communication mode: 12C
  • Python
  • Einsteigerfreundlich
Module Communication mode Interface Note
Light sensor . Knob potentiometer . Sound sensor ADC Port3/Port4 analog input
Joystick . Humiture sensor . Gesture sensor . Color sensor 12C Port1~Port6 digital input
Micro servo PWM Port3~Port6 PWM input
LED module single-bus Port1~Port6 -
PIR sensor . Dual button . Photoelectric switch IO Port1~Port6 General IO
Joystick
  • Connection mode: connect to any green port of Magic Box (Portl ~Port6)
  • Wiring Cable: Universal Sensor Cable
  • X/Y output value: 10 ~ 250
  • Z output value: 0: release; 1: press
  • Voltage: 5V
  • Current: 50mA
Dual Button
  • Communication mode: IO
  • Voltage: 5V
  • Current: 50mA
PIR Sensor
  • Detection distance: 150cm
  • Delay period:  2s
  • Induction range: < 100°
  • Static current: < 60uA
  • Operating temperature: -20 ~ 80°C
  • Voltage: 5V
  • Current: 50mA
Gesture Sensor
  • Support gestures: Support gestures: up, down, left, right, forward, backward,clockwise, counterclockwise
  • Effective recognition distance: 5cm - 15cm
  • Voltage: 5V
  • Current: 50mA
Photoelect ric Sensor
  • Wiring Cable: Already attached
  • Value range: 0 (no shield), 1 (with shield)
  • Standard detection environment: sunlight less than 10000LX, incandescent lamp less than 3000LX
  • Object to be detected: transparent or opaque object
  • Operating temperature: -25°C~ 55°C
  • Response time: <2ms
Sound Sensor
  • Connection mode: connect to any green port of Magic Box (Port3 ~Port4)
  • Communication mode: ADC
  • Value range: 0-1023
  • Sensitivity:(48dB至52dB)@1kHz
  • Microphone impedance: 2.2k ohms
  • Microphone frequency: 16-20 kHz
  • SNR S/N: 54dB
Humiture Sensor
  • Temperature range: 0~60 °C/±1°C
  • Humidity range: 10-90% RH ±5% RH
  • Voltage: 5V
  • Current: 50mA
Color Sensor
  • Color detection result: 0: no color; 1: red; 2: green; 3: blue; 4: yellow; 5: black; 6: white
  • Color value RGB: 0~200 (a larger value indicates a darker color)
  • Voltage: 5V
  • Current: 50mA
LED Module
  • Communication mode: monobus
  • RGB range: 0~255
  • Brightness range: 0~100%
  • Voltage: 5V
  • Current: 50mA
Light Sensor
  • Voltage: 5V
  • Current: 50mA
Knob potentiometer
  • Output voltag: 0~2500mV
  • Brightness return value: 0-407 (extreme fluctuation is normal)
  • Voltage: 5V
  • Current: 50mA
Micro servo
  • Communication mode: PWM
  • Servo Speed: 0.1sec/60*/4.8V;0.09sec/60*/6.0V
  • Torque:1.6kg.cm/4.8V; 1.8kg.cm/6.0V
  • PWM frequency: 50Hz/0.5~2.5MS
  • Voltage: 4.8-6.0V
  • Current: 60mA
AI Camera Kit
  • Dimensions: 50mm* 44mm* 25mm
  • CMOS: 1/4inch
  • Image Pixels: 1M
  • Image Format: YUV/MJPG
  • Data Format: 240* 320.640*480. 1280 720
  • Maximum Image Transfer Rate: 1280* 720@30fps
  • Camera Control: Saturation, Contrast, Acutance
  • White balance: Auto
  • Exposure: Auto
  • Working Temperature: 0°C to +50°C
  • Operating voltage: DC 5V
  • Interface: USB 2.0
  • Voice input: Integrated microphone
  • Feature: All-in-one design, integrated microphone, distortion-free lens
  • Camera working angle: 0°-135°
  • Function: Face recognition, image recognition, OCR text recognition, speech recognition, etc.
Magic Box
  • MCU: ARM 32-bit Cortex-M4
  • Main frequency: 168 MHz
  • Voltage: 100V~240V AC, 50/60Hz
  • Power Input: 12V - 5A DC
  • Working Environment: -5°C - 45°C
  • Power: 60W Max
  • Communication: USB virtual serial port/serial port/Bluetooth
  • Programming Language: MicroPython
  • Software: DobotStudio/DobotLab
  • Weight: 98g
  • Size: 95 mm X 80 mm X 21.5 mm
Versandgewicht: 1,10 kg
Artikelgewicht: 0,85 kg
€ 499,95
