DOBOT Magician Sensor Kit
- SKU: MBS-SES-392
- GTIN: 0658917504724
- HAN: F2311027
- Category: Sensors
Manufacturers:
- Communication mode: 12C
- Python
- beginner-friendly
| Module | Communication mode | Interface | Note |
| Light sensor . Knob potentiometer . Sound sensor | ADC | Port3/Port4 | analog input |
| Joystick . Humiture sensor . Gesture sensor . Color sensor | 12C | Port1~Port6 | digital input |
| Micro servo | PWM | Port3~Port6 | PWM input |
| LED module | single-bus | Port1~Port6 | - |
| PIR sensor . Dual button . Photoelectric switch | IO | Port1~Port6 | General IO |
Joystick
- Connection mode: connect to any green port of Magic Box (Portl ~Port6)
- Wiring Cable: Universal Sensor Cable
- X/Y output value: 10 ~ 250
- Z output value: 0: release; 1: press
- Voltage: 5V
- Current: 50mA
Dual Button
- Communication mode: IO
- Voltage: 5V
- Current: 50mA
PIR Sensor
- Detection distance: 150cm
- Delay period: 2s
- Induction range: < 100°
- Static current: < 60uA
- Operating temperature: -20 ~ 80°C
- Voltage: 5V
- Current: 50mA
Gesture Sensor
- Support gestures: Support gestures: up, down, left, right, forward, backward,clockwise, counterclockwise
- Effective recognition distance: 5cm - 15cm
- Voltage: 5V
- Current: 50mA
Photoelect ric Sensor
- Wiring Cable: Already attached
- Value range: 0 (no shield), 1 (with shield)
- Standard detection environment: sunlight less than 10000LX, incandescent lamp less than 3000LX
- Object to be detected: transparent or opaque object
- Operating temperature: -25°C~ 55°C
- Response time: <2ms
Sound Sensor
- Connection mode: connect to any green port of Magic Box (Port3 ~Port4)
- Communication mode: ADC
- Value range: 0-1023
- Sensitivity:(48dB至52dB)@1kHz
- Microphone impedance: 2.2k ohms
- Microphone frequency: 16-20 kHz
- SNR S/N: 54dB
Humiture Sensor
- Temperature range: 0~60 °C/±1°C
- Humidity range: 10-90% RH ±5% RH
- Voltage: 5V
- Current: 50mA
Color Sensor
- Color detection result: 0: no color; 1: red; 2: green; 3: blue; 4: yellow; 5: black; 6: white
- Color value RGB: 0~200 (a larger value indicates a darker color)
- Voltage: 5V
- Current: 50mA
LED Module
- Communication mode: monobus
- RGB range: 0~255
- Brightness range: 0~100%
- Voltage: 5V
- Current: 50mA
Light Sensor
- Voltage: 5V
- Current: 50mA
Knob potentiometer
- Output voltag: 0~2500mV
- Brightness return value: 0-407 (extreme fluctuation is normal)
- Voltage: 5V
- Current: 50mA
Micro servo
- Communication mode: PWM
- Servo Speed: 0.1sec/60*/4.8V;0.09sec/60*/6.0V
- Torque:1.6kg.cm/4.8V; 1.8kg.cm/6.0V
- PWM frequency: 50Hz/0.5~2.5MS
- Voltage: 4.8-6.0V
- Current: 60mA
AI Camera Kit
- Dimensions: 50mm* 44mm* 25mm
- CMOS: 1/4inch
- Image Pixels: 1M
- Image Format: YUV/MJPG
- Data Format: 240* 320.640*480. 1280 720
- Maximum Image Transfer Rate: 1280* 720@30fps
- Camera Control: Saturation, Contrast, Acutance
- White balance: Auto
- Exposure: Auto
- Working Temperature: 0°C to +50°C
- Operating voltage: DC 5V
- Interface: USB 2.0
- Voice input: Integrated microphone
- Feature: All-in-one design, integrated microphone, distortion-free lens
- Camera working angle: 0°-135°
- Function: Face recognition, image recognition, OCR text recognition, speech recognition, etc.
Magic Box
- MCU: ARM 32-bit Cortex-M4
- Main frequency: 168 MHz
- Voltage: 100V~240V AC, 50/60Hz
- Power Input: 12V - 5A DC
- Working Environment: -5°C - 45°C
- Power: 60W Max
- Communication: USB virtual serial port/serial port/Bluetooth
- Programming Language: MicroPython
- Software: DobotStudio/DobotLab
- Weight: 98g
- Size: 95 mm X 80 mm X 21.5 mm
| Item information | Value |
| Shipping weight: | 1,10 kg |
| Item weight: | 0,85 kg |
