AIRLink Telemetry Air Module
  • Range of 20km
  • AES-256 encryption
  • Data rate: 25 Mbps
  • 50x50x30mm
The AIRLink Telemetry Air module is very compact with a dimension of 50x50x30mm and very light with 50g. This module provides a broadband, AES-256 encrypted private channel over 20km.
Technical Data
  • Technology: 2x2 MIMO
  • Frequency: 2402 - 2477 MHz
  • Power: up to 30 dBm / 1W
  • Bandwidth: 4 / 8 MHz
  • Latency: less than 100 ms
  • Range: 20 km
Other data
  • visibility: direct, line of sight
  • ambient temperature: -40 - +50°C
  • power input: 5V DC, 2A min
  • antennas: 2x SMA Omni 3dBi, 50cm cable
  • Interfaces: Ethernet, fan Output
  • 1 x AIRLink Telemetry Air Module
Item weight: 0,05 kg
€ 1.341,95
