AIRLink Telemetry Ground Module
  • Compact and lightweight
  • Micro USB port
  • HD video
  • 20km range
  • AES encryption
The SmartLink Ground Module is very light and compact. In addition, it has a micro USB port. Thus, it is possible for this module to interact with any type of device. Laptops, tablets, desktop computers and smartphones are supported. For this, you just need to connect the module and download the SmartAP GCS app.
  • HD video: 1080p@60 fps, 1080p@30 fps, 720p@60 fps, 720p@30 fps
  • Telemetry TX / RX via UART TTL
  • Control Full manual control
  • Software Windows, iOS, MacOS, Android
Radio
  • Technology: 2x2 MIMO
  • Frequency: 2402 - 2482 MHz
  • Power: up to 30 dBm / 1W
  • Bandwidth: 4 / 8 MHz
  • Encryption: AES
  • Data rate: 25 Mbps
  • Latency: < 100 ms
  • Range: 20 km
Environment
  • visibility: line of sight
  • ambient temperature: -40...+50°C
Connectivity
  • Micro USB x1
  • power input x1
  • SMA antenna x2
  • 1 x AIRLink Telemetry Ground Module
€ 1.654,95
