AIRLink Telemetry Set
  • 20km range
  • 1000mW (30 dBm) output power
  • AES-256 encryption
The AIRLink Telemetry Set is a separate telemetry module for SmartAP AIRLink. It provides a broadband, AES-256 encrypted private data channel over 20km for UAVs/drones.
SmartAP GCS provides all status information over the radio link, including RSSI, SNR and packets. It thus allows all important settings to be changed dynamically. For example, bandwidth, frame rate or power can be changed easily with one click. Via the ground module the configuration of the remote module is done automatically.
  • 1 x AIRLink Telemetry Air Module
  • 2 x Flat Panel Antenna 2.4 GHz
  • 1 x AIRLink Telemetry Ground Module
  • 2 x RPSMA Antenna 2.4 GHz
  • 1 x Telemetry cable
  • 1 x Ground module power cable
€ 2.845,95
Docs MYBOTSHOP documentation
