ARK Flow MR
  • SKU: MBS-SES-368
  • GTIN: 0658917515386
  • HAN: ARK-Flow-MR
  • Category: Pixhawk & RFD
ARK Flow MR
  • NDAA compliant
  • DroneCAN optical flow and mid-range distance sensor module
Next Generation PX4FLOW / ARK Flow
  • Drop-in replacement for ARK Flow
  • Supports UAVCAN firmware updates
  • ROS2 support
Sensors
  • PixArt PAA3905 Optical Flow Sensor
    • Wide working range from 80 mm to infinity
    • No focal length calibration required
    • Automatic detection of challenging surfaces (e.g. checkerboards, stripes, glossy surfaces, yaw movements)
    • Automatic switching of operation mode
    • 40 mW IR LED built into the board for improved low-light performance
  • Broadcom AFBR-S50LX85D Time-of-Flight Distance Sensor
    • Typical range up to 50 m
    • Operates in ambient light up to 200,000 Lux
    • Laser aperture angle: 2° x 2°
  • Invensense IIM-42653 6-axis IMU
Connections
  • Two Pixhawk standard CAN connectors: 4-pin JST-GH
  • Pixhawk standard debug connector: 6-pin JST-SH
Power Supply
  • 5 V: 86 mA average, 90 mA max
  • Dimensions: 3 cm × 3 cm × 1.4 cm
  • Weight: 5 g
  • LED indicators
  • Made in the USA – NDAA compliant
  • 1× ARK Flow MR
  • Includes 4-pin Pixhawk standard CAN cable
Shipping weight: 0,15 kg
Item weight: 0,01 kg
€ 443,95
Docs MYBOTSHOP documentation
