AVerMedia Engineering Kit D131OXB NX Module 8GB
  • SKU: MBS-AVM-08
  • GTIN: 0658917501655
  • HAN: D131OXB 8GB
  • Category: Electronics
  • Seamlessly integrates cameras, SSD and thermal solutions
  • D131OXB provides a robust solution for a wide range of applications
  • enables live camera transmissions
Discover the AVerMedia Engineering Kit D131OXB, a high-performance system featuring the NVIDIA® Jetson Orin™ NX module. This highly efficient SoM enables advanced analytics while providing the flexibility to handle a variety of other embedded IoT applications.
The D131OXB is a ready-to-use product that seamlessly integrates cameras, SSD, and thermal solutions. It offers an outstanding user experience thanks to its optimized vertical mechanical design. The power input and extended 40-pin connector are cleverly placed at the bottom to avoid cable interference. The ability to support multiple cameras and its compact design make it a remarkable device.
The AVerMedia Engineering Kit D131OXB is ideal for several key industries:
AMRs (Autonomous Mobile Robots):
Through live camera feeds, the D131OXB AMRs allows for quick and flexible adjustment of the work process, resulting in a significant increase in productivity.
Smart Security:
Using video analytics, the intelligent security industry benefits from live camera feeds to improve and ensure community safety.
Smart Inspection:
Production benefits from intelligent inspection through fast and accurate detection thanks to live camera transmissions, which significantly improves quality control.
The AVerMedia Engineering Kit D131OXB provides a robust solution for a wide range of applications in various industries. Discover the possibilities of the future with this advanced and flexible system for your industrial needs.
Specifications:
  • 2 x 2 lane MIPI CSI-2 camera input
  • 1 x 4 lane MIPI CSI-2 camera input
  • 2 x M.2. for Wi-Fi, SSD and capture card
  • 1 x GbE RJ-45 (PoE option), 40-pin expansion header
  • 4 x USB3.2 Gen1 (5G) Type A and 1 x 4Kp60 HDMI output
  • Operating temperature: 0°C ~ 70°C (TBD)
  • Dimensions: 157mm(W) x 105mm(L) x 85mm(H) with stand (without antenna)
  • 1x AVerMedia Engineering Kit D131OXB 8GB
€ 1.539,95
Manufacturers recommended retail price: € 1.570,95
(Save 1.97%, i.e. € 31,00)
