AVerMedia Fan module designed for Xavier NX
  • SKU: MBS-AVM-16
  • GTIN: 0658917502133
  • HAN: Xavier NX fan module
  • Category: Electronics
  • Power consumption: 1W
  • Rate speed: 6000 RPM
  • Air Flow: 7.66 CFM
  • Noise Level: 31dBA
  • MTBF: 70,000 Hrs
Fan Module designed for Xavier NX - Efficient Cooling Solution
The Fan Module designed for Xavier NX provides an efficient cooling solution for your devices. With its impressive specifications, it's the ideal choice to maintain optimal operating temperatures.
Specifications:
  • Power Consumption: This fan module has a low power consumption of 1 watt, contributing to energy efficiency while effectively cooling your system.
  • Rate Speed: With a rate speed of 6000 revolutions per minute (RPM), this fan module ensures rapid and efficient airflow.
  • Air Flow: The module provides an air flow rate of 7.66 cubic feet per minute (CFM), helping to maintain optimal temperatures within your device.
  • Noise Level: Despite its performance, the noise level of this fan module remains at just 31 decibels (dBA), ensuring a quiet working environment.
  • MTBF (Mean Time Between Failures): With an impressive MTBF rating of 70,000 hours, you can rely on the long-term reliability of this fan module.
The Fan Module designed for Xavier NX is specifically engineered to meet the cooling needs of your Xavier NX-based solutions. It ensures your devices operate at their best and provides longevity to your technology.
  • 1x Fan module designed for Xavier NX
€ 65,95
