AVerMedia MIPI cam dedicated for Jetson
  • SKU: MBS-AVM-11
  • GTIN: 0658917501686
  • HAN: POE board for D131OXB
  • Category: Electronics
  • Excellent image quality
  • Jetson-optimized
  • IEEE802.3af PSE support
  • Rugged construction
  • Versatile application possibilities
AVerMedia MIPI Camera - Optimized Image Quality for Jetson Platforms
Experience top-notch image quality and seamless integration into your Jetson applications with the AVerMedia MIPI Camera. This dedicated camera module is specifically designed for the Jetson platform, offering impressive performance and flexibility.
Key Features:
  • Outstanding Image Quality: The AVerMedia MIPI Camera delivers exceptional image quality that meets even the most demanding requirements. Capture crisp images and videos for your applications.
  • Jetson-Optimized: The camera is designed to work seamlessly with Jetson platforms. Easy integration allows for rapid development and deployment of your projects.
  • Support for IEEE802.3af PSE: This camera is compatible with IEEE802.3af PSE, meaning it can be powered by Power Sourcing Equipment, providing you with a convenient and reliable power supply option.
  • Rugged Construction: The AVerMedia MIPI Camera is designed for industrial use and can withstand the demands of challenging environments.
  • Versatile Applications: From image processing to machine learning, this camera is versatile and adaptable to your specific requirements.
Whether you're working on autonomous vehicles, robotics projects, or other demanding applications, the AVerMedia MIPI Camera is the perfect choice for capturing sharp images and seamlessly integrating into your Jetson solution.
  • 1x AVerMedia MIPI cam dedicated for Jetson
€ 129,95
