Aerotate CAN-i2C-Distribution Board
  • Compatible with: Ardupilot / PX4 / Pixhawk
The Aerotate CAN/I²C Distribution Board is a compact distribution board for CAN and I²C connections in drone and robotics projects. With a total of six 4-pin JST-GH ports and solder pads on both sides, it provides a flexible base to connect multiple devices cleanly to a bus. Compatible with Ardupilot, PX4, and Pixhawk.
The board distributes incoming CAN or I²C signals to several devices without the need for Y-cables or adapters. If an additional cable is not to be connected via JST-GH, leads can be soldered directly onto the solder pads on either side of the board. A pre-attached double-sided adhesive pad allows for easy and secure mounting onto a carrier frame or housing.
Technical Data
Item CAN / I²C Distribution Board
Ports 6× 4-pin JST-GH
Solder pads Both sides – for soldering additional cables directly to the board
Bus types CAN, I²C
Compatibility Ardupilot / PX4 / Pixhawk
Mounting Double-sided adhesive pad (included)
Manufacturer / origin Aerotate
Product Features
  • Versatile ports: 6× 4-pin JST-GH for straightforward, clean distribution
  • Solder tabs: allow easy soldering of additional cables directly to the board
  • Mounting: double-sided adhesive tape for easy and secure attachment
  • Compatibility: matching cables are also available
Scope of Delivery
  • 1× CAN / I²C Distribution Board
  • 1× Double-sided adhesive pad
Note: For longer CAN bus topologies, ensure correct termination at the bus ends. The distribution board itself does not include a termination resistor – this must be added externally if required.
€ 21,95
