Aerotate aeroPAX6 Carrier - DCDC 5V
  • SKU: MBS-Z1-131
  • GTIN: 0658917504939
  • HAN: aeroPAX6 Carrier - DCDC 5V
  • Category: Charging
  • Output voltage: reliable 5 V / 10 W DC power supply
  • specifically designed for integration into the aeroPAX6 carrier board
The Aerotate aeroPAX6 Carrier – DCDC 5V is a DC/DC power converter designed for integration into the aeroPAX6 Carrier board. It provides a reliable 5 V / 10 W DC supply for connected applications such as sensors, companion computers, or logic boards.
The aeroPAX6 Carrier board is adapted to this converter and delivers a stable additional power source alongside the existing main supply paths. The compact design minimizes space requirements and keeps the overall installation streamlined – ideal for drone, robotics, and research applications that require a clean 5 V rail.
Technical Data
Item aeroPAX6 Carrier – DCDC 5V
Type DC/DC converter module for aeroPAX6 Carrier
Output voltage 5 V DC
Output power 10 W
Integration Direct plug-in onto the aeroPAX6 Carrier board
Manufacturer / origin Aerotate
Product Features
  • Stable output: reliable 5 V / 10 W DC supply
  • Easy integration: simple installation onto the aeroPAX6 Carrier board
  • Compact design: minimal space requirements, streamlined system layout
  • Practical add-on for the aeroPAX6 Carrier with an additional power supply option
Scope of Delivery
  • 1× aeroPAX6 Carrier – DCDC 5V (converter module)
Note: The module is designed specifically for integration with the aeroPAX6 Carrier board and is supplied without the carrier board. Before commissioning, follow the specifications given in the Aerotate datasheet and Carrier manual.
€ 29,95
