AgileX Titan
AgileX Titan
  • 300 kg load capacity
  • Dynamic suspension system
  • Hot-swapping function
  • Expandability and further development
  • Remote controller
The TITAN is equipped with a steering knuckle on the front and rear axles, which significantly increases its off-road capability. Adaptive swing arms and shock absorbers ensure stability and flexibility. It meets vehicle standards and is ideal for industrial automation, logistics, research and more.
The TITAN's adaptive front suspension arms and rear shock absorbers effectively increase the ground contact area, significantly improving braking performance, handling and cornering stability.
The TITAN's dynamic suspension system increases traction, improves stability and ensures a smooth ride on a variety of challenging terrains.
The hot-swapping function enables a quick battery change during operation, which simplifies maintenance of the robot and speeds up battery replacement.
The TITAN is equipped with aluminum T-slot rails that allow secure mounting of external sensors or kits. It supports the CAN bus protocol and offers open source SDK and software resources for advanced Features.
  • Dimensions: 1550 x 980 x 710 mm
  • Platform weight: 280kg
  • Max payload: 300kg
  • Climbing ability: </= 10° (with load)
  • IP Rating: IP54
  • Communication: Standard Can, 232 Serial port
  • Max Speed: 2,4 m/s
  • Max travel: <25km
  • Obstacle clearance: 100mm
  • Charger:AC 220V Independent Charger
  • Charging Period: 1h(Single Battery)
  • AgileX Titan
  • AgileX remote controller
Shipping weight: 350,00 kg
Item weight: 280,00 kg
€ 24.799,95
