ArduCAM 21MP IMX230 Color Camera Module Pivariety
  • SKU: MBS-SES-185-29
  • GTIN: 0618455044038
  • HAN: B0324
  • Category: Sensors
  • 21MP Sony IMX230 Exmor RS™ color sensor, up to 5344×4012@9 fps.
  • Auto Exposure, Auto White Balance.
  • Programmable focus control.
  • Gstreamer support.
  • Upcoming V4L2 support
  • Compatible w/ all libcamera-based apps maintained by the RPi foundation.
The ArduCAM team has released a series of camera modules for the Raspberry Pi, including 5MP and 8MP modules. They are fully compatible with the official version and are divided into Standard Version, Optimised Optical Performance Version, Miniature Spy Camera Version, NoIR Version, Motorised IR Cut Version and Programmable Motorised Focus Camera Version. These camera modules support all Raspberry Pi models and require a 15-to-22 pin cable or adapter to work with the Pi Zero.
Arducam Pivariety is a Raspberry Pi camera solution to take the advantage of using its hardware ISP functions. Using Arducam Pivariety camera modules, users can get better performance and a wider variety of camera, lens options. For a long time, Raspberry Pi users are limited to use the closed-source official supported camera driver and camera modules (V1/V2/HQ). Now Arducam made it possible to provide well-tuned ISP for Pivariety camera modules with Auto Exposure, Auto White Balance, Lens Shading Correction, etc.
  • Upcoming V4L2 support(Although the V4L2 interface is supported, only RAW format images can be obtained, without ISP support).
Applications:
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • IoT
  • Face Recognition
  • Defect Detection
Technical data:
  • Pixel Size: 1.12um x 1.12um
  • Optical Size: 1/2.4”
  • Active Pixels: 5344H × 4016V
  • Lens Spec: Focal length: 4.77mm, F.NO: 1.75±5%, FOV: horizontal 64deg
  • IR Sensitivity: Integral IR filter, visible light only
  • Focus Type: Motorized focus, programmable focus control
  • Frame Rate: 5344×4012@9 fps, 3840×2160@10 fps, 2592×1944@15 fps, 2656×2004@30 fps, 1920×1080@30 fps, 1280×960@120 fps, 1280×720@120 fps, 640×480@120 fps
  • Sensor Output Format: RAW10
  • ISP Output  Format: Output image format of JPG, YUV420, RAW, DNG; output video format of MJPEG, H.264
  • Interface Type: 2-Lane MIPI
  • Board Size: 38x38mm
Scope of delivery:
  • 1 x Arducam 21MP IMX230 ISP-Camera Module
  • 1 x 150mm 22pin 1.0mm FPC Cable
  • 1 x 150mm 15pin 1.0mm to 22pin 0.5mm Pitch FPC Cable
  • 1 x acrylic case kit with assembly accessories
Shipping weight: 0,45 kg
Item weight: 0,20 kg
€ 174,95
Docs MYBOTSHOP documentation
