ArduCAM 5MP NoIR Standard Pi Camera
  • SKU: MBS-SES-185-02
  • GTIN: 0618455044014
  • HAN: B003301
  • Category: Sensors
The ArduCAM 5MP MoIR Standard Pi Camera:
  • is natively compatible with the official modules and motherboards
  • does not have an IR filter
  • is a night vision camera with external light sources
  • works with Raspicam commands and Python scripts
  • is used on Raspbian, MotionEye, OctoPi, as a surveillance camera and other Pi-Cam Projects.
The ArduCAM team has released a series of camera modules for the Raspberry Pi, including 5MP and 8MP modules. They are fully compatible with the official version and are divided into Standard Version, Optimized Optical Performance Version, Miniature Spy Camera Version, NoIR Version, Motorized IR Cut Version and Programmable Motorized Focus Camera Version. These camera modules support all Raspberry Pi models and require a 15-to-22 pin cable or adapter to work with the Pi Zero.
The NoIR version is natively compatible with the official Raspberry Pi camera modules and motherboards. It can be used as a night vision camera with external light sources, such as IR LED illuminators. It is able to work with Python scripts and Raspicam commands.
Usage on: Raspbian, MotionEye, OctoPi for your 3D printer, surveillance camera or other Pi cam projects.
Technical data:
  • Sensor: OV5647
  • Resolution: 5MP
  • Still image: 2592 x 1944 Max
  • Video: 1080 Max
  • frame rate: 30fps@1080P, 60fps@720P
  • IR sensitivity: no IR filter, sensitive to IR
  • Focus type: fixed focus
  • Field of view: 54° x 41° (horizontal x vertical)
  • Size of the board: 25 mm x 24 mm
  • Connection: 15pin MIPI CSI
  • Peak current: 300 mA
Scope of delivery:
  • 1 x ArduCam 5MP NoIR Standard Pi Camera
€ 20,95
Docs MYBOTSHOP documentation
