ArduCAM 8MP IMX219 Wide Angle Cam (No Board)
  • SKU: MBS-SES-185-20
  • GTIN: 0618455044021
  • HAN: B0180
  • Category: Sensors
  • Replacement for the lens sensor IMX219
  • Applicable on the Raspberry Pi camera module V2 and the Nvidia Jetson Nano
  • Easy installation by replacing the original IMX219 module
  • Grazing angle 175°(D) wide angle M12 lens
  • Your Raspberry Pi camera module V2 gets an improved viewing comfort
The ArduCAM team has released a series of camera modules for the Raspberry Pi, including 5MP and 8MP modules. They are fully compatible with the official version and are divided into Standard Version, Optimised Optical Performance Version, Miniature Spy Camera Version, NoIR Version, Motorised IR Cut Version and Programmable Motorised Focus Camera Version. These camera modules support all Raspberry Pi models and require a 15-to-22 pin cable or adapter to work with the Pi Zero.
This Arducam IMX219 fisheye camera module is mainly designed for Raspberry Pi V2 camera board and Nvidia Jetson Nano, and replaces the standard IMX219 camera module to get a much wider field of view. It can be used for drones, robots, action cameras and 3D scanning applications.
Technical Data:
  • Sony 8MP IMX219 Sensor
  • Optical Format: 1/4 inch
  • Frame Rate: 30fps@8MP, 60fps@1080p, 180fps@720p
  • Data Format: RAW8/RAW10
  • EFL: 2.5mm
  • F.NO: 2.8
  • Focus Type: Fixed Focus
  • View Angle: 175(D) x 155(H)  x 115(V)
  • Interface: MIPI CSI-2 2-lane/4-lane
  • IR Sensitivity: Integral IR Filter, visible light only
Application:
  • Space Exploration
  • Medicine
  • Biological/Physical Research
Scope of delivery:
  • 1x Arducam IMX219 Wide Angle Camera Module
Note: A Raspberry Pi V2 camera board is required to use this camera module.
€ 35,95
Docs MYBOTSHOP documentation
