Arducam 12MP IMX708 75°(DFOV) FF HDR MIPI Camera Module
  • SKU: MBS-SES-185-45
  • GTIN: 0658917504922
  • HAN: B0638
  • Category: Sensors
  • for Raspberry Pi
  • supplied with the appropriate 15-pin to 22-pin and 15-pin to 15-pin FPC flat cables
The Arducam 12MP IMX708 75° (DFOV) Fixed-Focus HDR MIPI Camera Module is a fixed-focus variant of the official Raspberry Pi Camera Module 3. It uses the high-quality Sony IMX708 11.9 MP sensor with HDR mode and a 75° diagonal field of view. The combination of stable fixed focus, integrated IR-cut filter, and MIPI CSI-2 interface delivers consistently sharp, instantly available images without autofocus latency.
With its fixed-focus lens, the module provides especially fast and stable image results – ideal for applications where predictable sharpness and short image availability are more important than variable focus distances. The Sony IMX708 supports an HDR mode with output up to 3 MP, enabling detail-rich images even in high-contrast scenes.
The camera module is compatible with the Raspberry Pi 3, 4 A/B, and 5 and ships with both 15-22-pin and 15-15-pin FPC flexible cables – ready to use right out of the box. As a complementary product to the Raspberry Pi autofocus variant, it offers an outstanding price-performance ratio.
Technical Data
Item Arducam B0638 – 12MP IMX708 75° fixed focus
Image sensor Sony IMX708, 11.9 MP
HDR mode Yes, output up to 3 MP
Lens 75° diagonal field of view (DFOV), fixed focus
IR-cut filter Integrated
Interface MIPI CSI-2
Compatibility Raspberry Pi 3, 4 A/B, 5
Cables included 15-22-pin FPC + 15-15-pin FPC flexible cable
Manufacturer Arducam
Product Features
  • Complementary to the Raspberry Pi V3 autofocus camera: fixed-focus variant with the same sensor
  • Superior sensor: Sony IMX708 with HDR mode for detail-rich images
  • Fixed focus: 75° DFOV with integrated IR-cut filter – stable, instantly available images
  • Wide platform compatibility: Raspberry Pi 3, 4 A/B, and 5 with both common FPC cables
  • Cost-effective: outstanding price-performance ratio at this image quality level
Typical Applications
  • Stationary maker and educational projects with Raspberry Pi
  • Surveillance, time-lapse, intercom systems
  • Computer vision and AI inference with a fixed focal length
  • Embedded vision applications where autofocus latency must be avoided
  • HDR shots in high-contrast indoor / outdoor scenes
Note: The fixed-focus variant is best suited to applications where the distance to the subject is largely constant. If variable focus is required, the Raspberry Pi Camera Module 3 with autofocus is the better choice. For other angles of view, the Arducam variants B0639 (120° DFOV) and B0310 (152° DFOV ultra-wide) are also available.
Scope of Delivery
  • 1× Arducam 12MP IMX708 FF MIPI camera module
  • 1× 15 cm FFC flexible cable, 15-15-pin
  • 1× 15 cm FFC flexible cable, 15-22-pin
€ 35,95
